Need reluctor wheel help
Old 08-16-2007, 09:40 AM
My90Iroc's Avatar
Default Need reluctor wheel help
I have an aluminum 6.0L block and crank but I'm not sure what car they're out of. It's going into a car with an LS1 computer so naturally I need an LS1 reluctor. On the crank I have the outside (rear most) wheel has 24 teeth. Is that the 24 teeth I'm looking for with the LS1 or do you count the combined teeth on both wheels?
If I do have the wrong setup is it possible to just buy the reluctor wheels and swap them over?
Dealerships are telling me I can only get them with a new crank.
Old 08-17-2007, 09:38 AM
My90Iroc's Avatar
Any ideas?
Old 08-17-2007, 09:42 AM
xssive's Avatar
You have a reluctor made of two welded plates. You count the teeth on one of the plates so yes you have a 24x. You would know if its a 58x b/c there is a single plate with really small teeth
Old 08-17-2007, 11:07 PM
Dial In GTO's Avatar
24 tooth is what you need.
Gary
