best way to pull timing only when th kit is on (LT1)
Old 08-21-2007, 05:45 PM
ZeeTwentyFate's Avatar
Default best way to pull timing only when th kit is on (LT1)
like i said whats the best way to pull timing only when the kit is on on a LT1 i know LS1's have the timing tuner, i have an ignition box but it only pulls constant timing so im losing 5* all night if i ride but i only need it pulled when running someone. is ther a way to prgram this in to the PCM with tunercat? any suggestions are appreciated
Old 08-21-2007, 05:57 PM
jmill96Z's Avatar
Tunercat can pull timing at WOT, so if you're just cruizing around at partial throttle it will have regular timing, then when you hit it you will drop timing.
Old 08-21-2007, 06:07 PM
yeah but i want it only when WOT on spray not WOT all the time...
Old 08-21-2007, 06:49 PM
SLowETz's Avatar
Timing Tuner. Pulls pre-determined timing when system is armed. Can be configured to pull timing at pre-determined rmp whether NA or N2o armed. Also acts as a window switch, and activation delay up to .08 sec.
Old 08-21-2007, 07:30 PM
yeah but thats for LS1's not LT1's
Old 08-21-2007, 07:52 PM
SLowETz's Avatar
My bad-
