Tuner Question on Recent Dyno...
Old 08-23-2007, 05:59 PM
Chef's Avatar
Default Tuner Question on Recent Dyno...
It's very hot here in Arizona and well over 100. Today for the first time in a while the car was up on a Mustang Dyno -
471rhwp first pull...?????It still needs to be be fully tuned as this was the start of the tuning but I was expecting much more?
Question - How much hp difference can quality tuners make? Meaning two well known tuners going head to head - could the difference be 50hp-100hp difference?
What is the average increase on a Dynojet -
I've been on both and others but is there a formula increase on the Dynojet or just knowing it's more kind of thing.
Also - Is there a formula for loss in hp due to weather temps etc...
My goal is 530 - 550 rwhp with my current mods - Am I way off?
Thanks,
Chef
Current mods -
100% Blacked Out "V"|Katech 427 Stroker|Custom Tuned|AFR Ported & Polished Heads|Nasty Cam|FAST Intake|90mm TB|Kooks Headers 1 7/8|Custom X Pipe|B&B Tubes|UUC Short Shifter & V-****|BMR Toes & Arms|BMR Cradle Support|Hotchkis Sways|T2 Race Shocks|Ground Control Coilovers 600/650|SS Brake Lines|Hawk HP Plus Pads|BMR Strut Tower Brace|Spec Stage 3+ Clutch & Flywheel|"Grid" Pedals|Specter Werkes Carbon Fiber Extractor Hood|Spoiler|
Old 08-23-2007, 07:09 PM
Billiumss's Avatar
If your air/fuel is around 12.7-12.9 and your timing is around 25-27 degrees, there is not much else you can do to make 50-100 HP more, maybe 5-10.
Mustang dynos are about 15% less than a Dynojet....
Old 08-23-2007, 08:48 PM
Chef's Avatar
copy that...
Thanks,
Chef
Old 08-23-2007, 11:10 PM
Frost's Avatar
+1; and that number would be even less if the two tuners used the same dyno with the same weather conditions close to the same day.
Old 08-24-2007, 08:22 AM
7 Second Club
NicD's Avatar
Making power is the easy part as it's just timing and fuel. Making it drive nicely, etc is the hard part. A mustang dyno reads anywhere from 10-15% lower than a dynojet.
Old 08-24-2007, 10:21 AM
edcmat-l1's Avatar
+2.....
Old 08-24-2007, 10:28 AM
edcmat-l1's Avatar
+1....Well stated. Couldnt have said it better.
Old 08-24-2007, 11:39 AM
Frost's Avatar
Haha but you'd never know that reading the dyno section.... every setup that doesn't make ungodly numbers and it's "probably a bad tuner or tune" ...
Old 08-24-2007, 12:01 PM
koolaid_kid's Avatar
Well, duh, absolutely. Don't you realize that the real world is just a very long dyno without the tie downs?
