Strang wide band readings
Old 09-01-2007, 02:04 AM
mxmccarter2401's Avatar
Default Strang wide band readings
when i'm at idle or decel the wideband maxes out on the lean side. Is this normal? thanks guys.
Old 09-03-2007, 06:18 AM
Killer_Bluebird's Avatar
What wideband are you using? I got erratic reading like that when I did a free air calibration of the sensor while it was still inside the Y-pipe. After I removed the sensor from the exhaust and re-did the calibration It started working correctly.
Old 09-03-2007, 06:43 AM
macca_779's Avatar
decel is probably normal because of DFCO. The idle issue is not normal though.
Old 09-03-2007, 01:11 PM
Its an autometer wide band gauge. It didn't say anything about a free air calibration in the instructions. And what is DFCO?
Old 09-03-2007, 02:02 PM
LS1TECH Sponsor
foff667's Avatar
Deceleration fuel cut off
Old 09-03-2007, 09:22 PM
Shallow Bay's Avatar
It will almost completely cut fuel and retard timing.
Old 09-03-2007, 10:42 PM
That makes sense. what about the idle issue?
Old 09-04-2007, 01:08 AM
2002_Z28_Six_Speed's Avatar
Exhuast fumes will sit in there for hours and hours. Takes more than overnight of sitting.
