p1018 causing fuel problems?
its a code for high voltage circuitry in the coolant temperature switch and it used to come on bc i had a bad sensor which i replaced, it came on again (i think the new sensor isn't making a good contact) but at the same time two more codes came on, one factory fuel system and another one i can't remember, should i clear em and see if they come back or any advice?
