Which tuner to adjust for bigger injectors?
I plan on installing larger injectors on my 2000 LS1 Z28 and need to know what would be the cheapest, most basic tuner I can buy, to adjust for the larger injectors.
Are you going to need any other tuning? If you only need a tune for larger injectors you might just have someone do it for you. If you are planning on needing more changes in the future you should plan on doing your own. It does take time to learn to tune but is worth it in the long run. I use EFILive and find it easy to use.
Bill
Bill
