Diablo mv readings?
Old 09-30-2007, 10:11 PM
djsanchez2's Avatar
Default Diablo mv readings?
Ok i have looked over the stickies and preformed searches to no avail.
I just wanted to confirm that
Higher Mv = 900+ Richer
Lower Mv = 890- Leaner
Also a question about the difference between night and day readings. I've been seeing 960-975Mv in the night and 930-945Mv in the day. Why do you suppose this is? Should i shoot for somewhere in the middle as a compromise? I would rather not run lean in hotter weather.
I do have LT's and ORY so know that the Mv reading will be bit higher and still be normal.
Oh and my LTFT's are doing good. I'm getting between 1.5 through -1.5 so i'm cool with those #'s. Any other suggestions?
Old 09-30-2007, 10:23 PM
LS1TECH Sponsor
foff667's Avatar
500+ means your richer than 14.7:1
400 & under means your leaner than 14.7:1
anything in between could go either way.
Theres really no accurate way to trust your stock o2's as they aren't meant to calculate wot fueling by any means.
