HP Tuner Question
Old 10-08-2007, 03:56 PM
camaro98z28's Avatar
Default HP Tuner Question
My Dell Laptop only has USB ports and my HP Tuner needs a Serial port connection. Does HP Tuner make a connector that uses USB?
Old 10-08-2007, 04:04 PM
TN94Z's Avatar
Yes they do or you can buy a serial to USB adapter for your laptop
Old 10-08-2007, 04:05 PM
TN94Z's Avatar
The new HPTuners MPVI is USB
Old 10-08-2007, 04:06 PM
What does a new unit cost or I wonder if that would swap mine?
Old 10-08-2007, 04:07 PM
TN94Z's Avatar
You can upgrade but it would be cheaper to go buy an adapter. The new version is better though. You can log in the car and not have to use the laptop.
LS1TECH Sponsor
foff667's Avatar
We don't make a connector, but our newer USB MPVI units(which you can upgrade to at any time via your customer login page) have a usb interface rather than a serial interface. Or you can purchase(as suggested) a usb to serial adapter.
Old 10-08-2007, 04:09 PM
edcmat-l1's Avatar
Check with foff667 on here (Bill@hptuners) about the serial to usb adapter. Theres been alot of issues with those with other things, not specifically hpt, but you never know.
they do sell a usb cable separately. You would probably be better off buyin that.
Old 10-08-2007, 04:18 PM
Right, I don't want something that is going to fail. Also you have to make the computer see that it's a Serial port and not a USB. Pain sometimes
Old 10-08-2007, 04:19 PM
How much is the upgrade?
Old 10-08-2007, 04:21 PM
edcmat-l1's Avatar
Musta posted that while I was typing mine
Old 10-08-2007, 04:45 PM
I sent a PM to Support. I'm having problem with loging in with my Serial Number
