Fuel pump relay control
On an 2002 PCM and harness, does the PCM ground the relay control or send a 12v signal?
We have run the car, we think its wired right, but the fuel pump wants to stay on all the time.
The realy is connected to constant power, and the relay is fed 12v expecting the PCM to ground out the circut, we think we assumed wrong and that we should ground the relay and the PCM should send a signal, Whats the verdict?
Ok we just assumed wrong, we figured that the PCM would ground the circut, so that explains why when the car was off the relay was grouding into the PCM and running. We just need to take the power wire on the relay and run it to ground and it will work fine. Thanks Frost.
