Ls1 swapped into fox body.. computer issues yet again
Old 10-24-2007, 09:22 AM
101mmSBC's Avatar
Default Ls1 swapped into fox body.. computer issues yet again
I worked out a bunch of bugs and now the car will start but it shuts itself right back off, it sounds like it just cuts fuel or spark, just as if you where to turn the key off. Is there something in the computer that needs to be disabled due to not using a vats key anymore?
Old 10-24-2007, 09:27 AM
Eurospec2's Avatar
Yep, sounds exactly like VATS is still activated in the PCM, have your tuner turn it off and you should be good
