speed density tune with 2 dtCs
Hey guys i have a question i have 2 codes p0102 and p0106 On is low frequency for the maf and the othere is a map sensor system code. Can i turn these off so that the car will not have the dtc in the pcm so i can pass emissions or will this cause a problem with the running of the car?
Kyle
Kyle
I have a maf and i have the tune done already. I just have to see if i can turn these codes off so i can make it thru emissions. The car has the speed density tune in it runs drives fine but cant pass emissinos with codes in the pcm. I have a magna charger on the car.
Are the codes all they check for your emissions in your area, or do they also run a sniffer on it?
Yes all they check is codes no sniffer. And Yes its a 2 bar speed density tune. So your saying with the maf code I "Should" be able to pass? You can pass down in mass with that code in there?
