Please give some kind of advice..will shorting a hot wire damage the pcm?
Old 11-01-2007, 09:46 PM
johnson7454's Avatar
Default Please give some kind of advice..will shorting a hot wire damage the pcm?
I have been fighting a knock sensor problem for about a year. Yeah i know! Anyways i have replaced both knock sensors and repaired the harness from someone else smashing it after installing the intake. I still do not get any volts from the harness. I checked at the pcm and nothing also. Could it have fried something in the pcm when the hot wires touched the block?
Old 11-05-2007, 12:47 PM
NoGo's Avatar
You could have knocked out the input on the PCM for that point. Do you have supply power to the knock sensors? Continuity to the PCM?
Old 11-05-2007, 01:12 PM
Moderator
jimmyblue's Avatar
Is this feed something that depends from the ENG SEN fuse
branch? Any other "coincidentally" FU sensors that might give
you an indication of a common fault point?
Old 11-05-2007, 03:23 PM
edcmat-l1's Avatar
The knock sensor circuits are dedicated circuits. Make sure you have them unplugged from the sensors when you're testing them for voltage. Should be 5 volts disconnected, 2.5 volts connected. You may want to ohm the harness from the PCM connector to the sensor connector. Make sure both connectors are unplugged for this test too.
Old 11-07-2007, 07:38 PM
ecuexchange's Avatar
Default pcm and knock sensors
hey i can get you additional knock modules for cheep if it's the case. or if you need a new or spare pcm i could get one for 100.00 plus shipping.
just email me at ecuexchange with any questions and i'd be glad to answer them, what ever like if you need a wiring diagram or some information ect what ever just email me. pretty much any and all ecu's up to 2001.
