P0300 after heads, pulley, TR224 install??
Old 11-10-2007, 02:05 PM
cals400ex's Avatar
Default P0300 after heads, pulley, TR224 install??
Ok, I know it is common to get a p0300 after a cam install. However, this is a fairly small cam that i put in. I only get this code at idle. Once the service engine soon light is on, it will go off if I go drive on the interstate for 15 or 20 minutes. The car has been tuned with HP tuners. The tuner said he made the code 20 % less sensitive, however that didn't help at all. Maybe he needs delete it below 2000 rpms or something? I have read it could be plugs, wires, the cam, valve springs, piston rings, leaking intake, underdrive pulleys, O2 sensors, etc. I just don't know where to start. I have NO miss from idle to 6200 (where my shift point is set at).
Old 11-10-2007, 02:53 PM
SSpdDmon's Avatar
Yeah, it's still too sensitive. Your tuner needs to increase your misfire detection tables some more or turn them off.
Personally, I increase them 3x - not just 20%.
Old 11-10-2007, 02:56 PM
JMBLOWNWS6's Avatar
Do not turn off your misfire counts. Just increase them as stated.
Old 11-10-2007, 03:20 PM
edcmat-l1's Avatar
Yep. I start by doubling them in and around the idle region. Usually have to triple for the more radical cams.
Old 11-10-2007, 04:49 PM
cals400ex's Avatar
I am not sure about the whole tuning thing. I guess you can double the sensitivity just at idle and not at higher rpms?
Old 05-11-2008, 05:17 PM
cals400ex's Avatar
does anyone know if i can double them just around idle to 3000 or will they double the whole rpm range?
