02 sensor vote, whats better
Old 11-11-2007, 10:57 AM
zrater's Avatar
Default 02 sensor vote, whats better
im not sure what sensor is in my lm-1 , but can u guys
tell me what sensor is better , bosch or denso ,
i might go with a permanent gauge and sensor and use
the lm-1 for others cars for diagnostics and tuning...
Old 11-11-2007, 11:32 AM
Rhino79's Avatar
My setup uses a Bosch.
Old 11-11-2007, 11:38 AM
zrater's Avatar
back to what i said,what sensor is better bosch or denso.. what sensor has
work longer or better quality for u.. ive seen some burn up on good
setups...
Old 11-11-2007, 11:50 AM
Rhino79's Avatar
I like my bosch setup, my sensor lasted on about 40 cars that I tuned on. And thats with pulling it ina and out and probably 2 0r 3 times on some of those cars. Plus with the Bosch you can get them at O-Reilly's for about $50. I have no experience with the denso style sensor.
Old 11-11-2007, 01:42 PM
ammuscleftw's Avatar
I used denso 02's on mine due to seeing alot of sluggish readings alot have complained of with bosch and i have had no issues with them so far. plus i may be wrong but im told they are better made... just my .02
Old 11-11-2007, 06:47 PM
Randy WS6's Avatar
I have the Vette Bosch and there sloooow , I will get the Denso next time, guaranteed
Old 11-11-2007, 07:17 PM
zrater's Avatar
ok , when were talking slow in responce i take it is the switch time from rich to lean swing. ive notice on stocker 02s they have diff in swing at idle.. my lm-1 sensor
has been thru hell and still works good. not sure what sensor comes with lc-1 and lm-1..........
Old 11-11-2007, 08:07 PM
Rhino79's Avatar
Bosch comes with them, and PLX uses Bosch on theirs as well.
Old 11-11-2007, 08:25 PM
Randy WS6's Avatar
I have the PLX wide band with the Bosch WB sensor it work perfect but the narrow band sensors have a very slow heat up or (switch point) at start up . after engine is hot. closed loop.
