LT1 scanning question
Let me start by saying that I did a search and I have read other post but I am left confused by what diagnostic scanned I can purchase for my 1995 Vette LT1. Every scanner that I have looked at (on line and in stores) are for 1996 and newer cars. What gives?
I am just looking for a scanner that can point out error codes and clear codes if need be.
Any help would be great.
Thanks
Marc
Thanks
Marc
If the '95 vette is the same as the '95 F body it has an OBDII port, but OBDI programming. If yours is the same you can get an OBDI scanner and use a jumper between the scanner/DLC connector to make it work. Shoebox has a link on his site on which pins to use, I'll post a link to if you need it.
Just re-read my post and sounds confusing...here's shoebox's link if you have the OBDII connector and OBDI PCM: http://shbox.com/1/xraycable.jpg
Thank you
Marc
The 94-95 Corvettes and 95 F-bodies had OBD1 computers but OBDII connectors.
AutoXray, for example, sells a special blue connector cable for use with their OBD1 scan tools and the OBD1 computer OBDII connector cars.
