AFR 205 and Mamo Cam (224/228) tune
Old 11-13-2007, 08:35 PM
k-mart's Avatar
Default AFR 205 and Mamo Cam (224/228) tune
Getting ready to install this cam. Its pretty common, so I was wondering if anybody had a tune they could send me to check out.
Thanks,
Kevin
Old 11-13-2007, 09:00 PM
edcmat-l1's Avatar
Check the tune repository for your software. I'm sure you'll find one thats real close.
Old 11-16-2007, 08:30 PM
Chalky's Avatar
If you don't find anything, let me know. I can hook you up.
Old 11-17-2007, 12:20 AM
Frost's Avatar
Man how do you like that setup? How does it drive? Have you run it at the track? Dyno numbers? What LSA is that cam?
I figure it's not a jack since you have a near setup to the OP.
Old 11-17-2007, 12:38 AM
Chalky's Avatar
Cam is on a 114 straight up. XER lobes. I just dyno'd yesterday. Car was a little lean which hurt the torque a bit. HP was 442, TQ was 402 I believe. HP peaked @ 6400 and was still making 428HP @ 6900. These are corrected numbers.
I like the setup. Hard to hide the fact that you have a cam. If I had to do it again, I might go to a 112 LSA just to move power down a bit. I followed the Tony Mamo recipe. The 224/228 with good compression jumps makes power from low to high RPM. I think Tony Mamo was shifting his 346 with this cam and setup @ 7100-7200.
Never had it @ the drags.
Old 11-17-2007, 06:00 AM
DaddySS's Avatar
I'd be really interersted in seeing your tune, I have Tony's 220 224 63cc setup and had a hard time getting timing and fueling set up to manage KR.
