Car won't stay running NEED HELP M6 - A3 swap
Old 11-21-2007, 06:19 PM
Krazy98Z28's Avatar
Default Car won't stay running NEED HELP M6 - A3 swap
Ok I just finished doing a M6 - A3 conversion, and we have not installed the pedals yet but my guy wanted to start the car up. He has not wired anything from the clutch switch yet, so he jumped the solenoid under the hood and he said the car fired up but didn't stay running.
WHy wouldn't the car stay running?
What's the best way to wire the clutch switch so I start the car, I don't have a neutral safety switch(I don't think). I'm using a stock A4 shifter right now and stock M6 wiring.
Marco
Old 11-21-2007, 06:45 PM
RUTAN TA's Avatar
The clutch switch will not keep it from running.
Old 11-21-2007, 07:57 PM
Krazy98Z28's Avatar
I figured that, so what could it be??
Old 11-21-2007, 08:45 PM
RUTAN TA's Avatar
Is the security light flashing?
Old 11-21-2007, 08:53 PM
LS1Tech Sponsor
Slowhawk's Avatar
Shorted out engine sensor fuse?
Old 11-21-2007, 09:40 PM
Krazy98Z28's Avatar
I wasn't there so I can't say if the security light was flashing or if the fuse was blown, once i get the pedals i will be there for start up and will evaluate more.
Just wanted to know if this was something cause by me not starting the car with the clutch switch jumped.
Old 11-21-2007, 11:34 PM
Frost's Avatar
what have you changed in the PCM to adjust for the increased load at idle of the stall vs. a disengaged clutch?
Old 11-22-2007, 08:46 AM
Krazy98Z28's Avatar
Nothing has been changed in the PCM.
The car is going to Slowhawk as soon as I get it back, I know Don will fix whatever issue I have, i'm just stressing over what the issue could be.
Old 11-22-2007, 01:26 PM
Frost's Avatar
don't stress, you don't even know if there actually IS an issue I'm sure Don will get you straight
Old 11-22-2007, 03:51 PM
Krazy98Z28's Avatar
It's a bad habit, I always expect the worst
Old 11-22-2007, 04:55 PM
Truckshop's Avatar
jump the solenoid with the ignition in the start position. the security is keeping it from staying running.
Old 11-22-2007, 05:45 PM
LS1Tech Sponsor
Slowhawk's Avatar
Well,it matter's if you can keep the car running ussing the gas peddle.If it dies no matter what then it is an issue.
Old 11-22-2007, 06:30 PM
Krazy98Z28's Avatar
That's what I assumed was happening but I wasn't sure if that was possible
