need help, KR problem
I'm getting 3-4° of retard at WOT. It's usually in the upper RPM range when it strikes 5-6K. i.e. If I roll into the gas it has 0° retard until 5K rpm. I've replaced the knock sensors (had a bad one), its still there. I've cleaned the MAF and IAT, still there. I've richened the A/F mixture 1% with the Preditor, still have KR just not quite as bad, 2-3° (it's blowing a little black smoke, which should mean it's rich already, right?). I'm running 93 octane, even tried a couple of different brands; Exxon, Texaco, Shell, etc. I know it's hot, but the KR is there whether its 70° or 90°+. In the winter it was around 1°. KR is only at WOT.
What else is there to try? Spark plugs? Did them last year. Coolant temp is pretty steady at 180°. I'm about to remove the Preditor tune and try bone stock this weekend. Any other ideas?
Moderator
Re: need help, KR problem
Black smoke is probably from lean misfire.
Lean makes hydrocarbons, rich makes CO (in
the region about stoich). You have more PE
range (-5% - +5%), why not try it out? Let
your O2s tell you where your mixture is at,
get it to 900-920mV and then mess your timing
around to whatever 900mV will take.
Bad top end fade might follow fuel pressure drop.
Wiring, filter and aged pump; injector crudding?
A logger like ATAP that tells you about individual
cylinder misfires might put you on the track there.
