Rev Limiter ?
Old 06-24-2003, 07:49 AM
Fast Eddie's 02 T/A vert.'s Avatar
Default Rev Limiter ?
How high can i set my rev limiter on a stock 02 T/A.without hurting the motor.How far would you take it?
Old 06-24-2003, 08:31 AM
trackbird's Avatar
Default Re: Rev Limiter ?
6200 RPM
Without valvetrain upgrades, I'd stick with the stock setting...that's part of why it's there. Just my thoughts....
Old 06-24-2003, 08:59 AM
trackbird's Avatar
That wasn't meant to be a smart answer (kinda sounded that way...sorry). I'd not push my luck without a change of springs and maybe a cam to make mor power up there as well....
Old 06-24-2003, 09:52 AM
I appreciate the input.I noticed when i was programming the HPP3 it had the capability to change the rev limiter.
I'm trying to find out how far i can push my LS1 for sundays race.
Old 06-24-2003, 10:43 AM
Cal
Cal's Avatar
LS6 engines have the rev limiter set to 6600 rpm but they have stiffer springs and lighter valves.
Old 06-24-2003, 10:45 AM
Cal
Cal's Avatar
Hey trackbird, are you running polyurethane sway bar busings on the rear end?
Old 06-24-2003, 11:29 AM
trackbird's Avatar
Nope....not yet. I started to, and started to again....and decided to buy swaybars with bushings (as soon as I get to it) and do it that way. Why do you ask?
Old 06-25-2003, 12:00 PM
Cal
Cal's Avatar
Well I have Prothane polyurethane swaybar bushings on both the front and back. The front ones are great, but noise from the rear busings is driving me crazy, so I'm thinking of switching back to 1LE bushings just on the rear. I'm just wondering if I will notice any difference in cornering; I really don't like compromises.
Old 06-26-2003, 07:20 AM
trackbird's Avatar
Noise? Hmmm....did you try to regrease them? You may have to pull them off to do them right. I suspect the 1le will be softer than the prothane. Just not sure how much.
Old 06-28-2003, 10:40 AM
Jpr5690's Avatar
whit a hpp3 im doing +3+6+9 mph and have my rev limit at 6400 from my calcs this would put the shifts in the 6300 range and im happy with it hypertech reccomended it to me so far all good
