Help Needed - 1969 Camaro E40 Codes
I've got eight codes, and need some help with them. If anyone has the troubleshooting steps related to these codes, it would be greatly appreciated. A little background on the setup. The car is a 1969 Camaro. The engine is a 6.0 24X based engine. The gas pedal is from a 2005 GTO, and the TB is from a 5.3 engine.
P0633 Immobilizer Key Not Programmed - ECM/PCM
P0689 Engine Controls Ignition Relay Feedback Circuit Low Voltage ECM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance ECM
P1629 Theft Deterrent Start Enable Signal Not Received
P1682 Ignition 1 Switch Circuit 2 ECM
P2101 Control Module Throttle Actuator Position Performance ECM
P2119 Throttle Closed Position Performance ECM
P2135 Throttle Position (TP) Sensor 1-2 Correlation ECM
Thanks Scott
Thanks Scott
