ms3, diablo, stalling... anything i can do?
Ok first stop laughing. . .
00'
A4
we just got done with the ms3 and upgraded valvetrain install and I understand that I need to hop on a dyno and let someone with some real soft wear tune this thing but for now is there anything i can do to get this thing to idle at all for now? i have the idle on the predator turned all the way up and i have the butterfly on the t.b. cracked, still wont idle. it also drives a bit sluggish normal driving... wot she pulls pretty hard though.
00'
A4
Have you got a stall? You need to set the idle up to the 900 range and the fuel will probably need to be cut down a little down low until you can get a good tune. It will probably learn idle out itself, to an extent that is. Good luck!
yes i have a yank 3600. . . and your right it was VERY rich, I run open headers with turn downs and I could see the fuel coming out from under the car by the door. I have since found I can make it idle perfect if a pull enough fuel using the "injector slope" feature with the hand held but then it leans it out so much while normal driving that it doesn't work out... I think the predator could probably do the job (some what) if it had a better base tune in it but I'm just gonna have to get this thing tuned on a dyno with someone that has more options. its almost like the fuel pressure is to high. If I make it think it has huge injectors to squirt less fuel, it will idle fine, but then there is not enough fuel to drive it safely.
Yeah, you need tuning software so you can tune the individual areas one by one instead of tuning a certain percentage across the board. Dyno tune sounds like your best bet; but you could also pick up the software and try your hand at tuning yourself. I know next to nothing about tuning but there is a lot of good info on this site and HP tuners site if you decide to go this route. I hear EFIlive has a good product and support also. I only know of HP tuners first hand and highly recommend it. But yeah, at least get a good dyno tune. I think you'll like the cam when it's all said and done. On a side note, why the small converter; gonna spray it?
00'
A4
00'
A4
. . .In refrence to the orginal topic, johan sent me another tune and she idles now. sounds outstanding. Thanks for all the help guys.
