Dual TBs and MAFs, stock PCM?
Suppose you wanted to build an LS-powered car in which using the normal forward-facing throttle body orientation was impossible and reversing the intake to face backward was doable but less than optimal. Suppose further that you wanted to use a custom intake similar to this Nissan -- i.e., crossed-over runners to interconnected plenums, each with its own side-facing throttle body and MAF. Would you have any chance of making this work (either drive-by-wire or cable TB) with a GM PCM, or would you be forced to use something more flexible like MoTeC?
Ok, let's first just deal with half the original questions. Would you have any chance of making dual throttle bodies work (either drive-by-wire or cable) with a GM PCM, or would you be forced to use something more flexible like MoTeC?
you could also run 2 GM pcms, one per side of the motor (Ford does this on the aston martin V12 (circe 2003-4ish) and Dodge did similar with a 4 cylinder and a 6 cylinder pcm on the original vipers.
I see no reason 2 mechanical throttle bodies could not be used, but you would need to have a crossover for the IAC motor, since I do not think 2 could be run in parallel. Only put a TPS sensor on one of the TB's and make sure both are opened/closed exactly the same.
Ryan
Ryan
