rev/speed limiter tuning for a th400, help please
Ok I have a 00 TA that I have swaped in a th400. the car was originally an A4 car. I'm tuning with efi live. the problem I'm having is that it seems like I have a rev limiter @6500 or around that. I have all the rev limiters that I can find and the fuel cutoff set over 7500rpm. not sure what i'm missing. thanks for any help you guys can give me.
I know someone this is happening to as well. I have looked in all the usual areas and can not explain it. He is using a 03 system, but the valet mode is not used. Interesting though, the limiter was kicking in at the rpm indicated by the valet mode even though it was not selected??? could this be. I have reset the rpm and will post later if this fixed it.
P.S. stand alone trans as well, using a six speed program.
Grim.
Grim.
