gauge cluster is wack
I have a 99 ls1 in a 94 camaro using all the 99 stuff. The problem is when the cluster was in my 99 everything worked. Now that its in my 94 the gas gauge, temp gauge and tach stopped working. I hooked up an autometer tach at the correct place, grounded it and it works fine. The other two were checked out on a scanner and seemed to be fine but still don't work. Is this a grounding issue and where should they be grounded? If you guys can get me some wiring diagrams for dummies it would be greatly appreciated.
