Tuning the GTP Bosch injectors?
Old 06-29-2003, 08:25 PM
LS1nitwit's Avatar
Default Tuning the GTP Bosch injectors?
What is involved in tuning The GTP Bosch 42# injectors with LS1edit to work on a LS1? I assume the GTP's have the same "characteristics" as a stock injector just flow more? All I would need to do is adjust the injector flow rate table to make them work? Any other tables? Anyone have a table they would like to share?
Old 06-29-2003, 09:22 PM
Bink's Avatar
Default Re: Tuning the GTP Bosch injectors?
They're the same injectors run on the World Challenge Cup cars. Same internal design as ls1 inj.No need to adjust offset table. Flow 42# at 58# fuel pressure. I have ported Ls6 heads, LGM headers,ported TB and bigger cam.... I started with this scale far IFR
Kpa @ 0=5.29
5=5.32
10=5.35
15=5.40
20=5.42
25=5.45
30=5.48
35=5.51
40=5.56
45=5.57
50=5.61
55=5.64
60=5.67
65=5.70
70=5.73
75=5.78
80=5.79
A bit rich at start up but within boundaries of PCM (+/- 25). HTH Good Luck!
joel(Bink)
Old 06-30-2003, 02:21 PM
LS1nitwit's Avatar
Thank you!
Old 06-30-2003, 04:17 PM
Bink's Avatar
Your welcome.
joel(Bink)
Old 07-01-2003, 10:55 PM
Bink's Avatar
Wow, This is a fantastic thread 42# Bosch/GM injectors Thanks John. Doesn't it figure ...I answer LS1nitwit's post and I'm the one getting the useful infi - I definitely need to rescale my injectors.
joel
Old 07-02-2003, 09:26 AM
NO CATZZ's Avatar
Sorry to get off topic here but what is the part # for these GTP injectors?
Thanks
Josh
Old 07-02-2003, 01:40 PM
Bink's Avatar
Josh,
GM Part- #24508208.GMPP has them.
joel
Old 07-02-2003, 02:04 PM
NO CATZZ's Avatar
Holey Monkey!!!
GMPP wants 90 bucks a piece
GM parts direct wants 55 bucks a piece
Anybody know of a cheaper way of getting these?
Quick Reply: Tuning the GTP Bosch injectors?
