turbo tune
You REALLY don't want to do that.
Find you a good competent tuner who is local to you unless you.
If not, you will either get a tuned that is smothered and way beneath your setup's potential or one that could be lean and/or aggressive timing-wise and break your setup all together... Looks like a lot of work to try and cut a huge corner at the end.
