Installed Cam Need Help on Tuning Issues!
Old 07-06-2003, 07:49 PM
z28man's Avatar
Default Installed Cam Need Help on Tuning Issues!
I installed a cam over the weekend and i tuned it with ls1 edit. the iac's seem to be around 50 to 65. we calculated the VE table by 50% to help surging problems at warm and cold starts. this seemed to help. but now after doing this stuff it seems that i have a little hesitation while pulling out or after reving the engine high. i try to feather the gas pedal to keep it running but the car does what it wants to and does'nt respond to me feathering the gas pedal. can anyone help me out on this? thanx in advance. the mods/cam size are in my sig!
Old 07-07-2003, 03:49 PM
Cal
Cal's Avatar
Default Re: Installed Cam Need Help on Tuning Issues!
Sounds like it needs more air. You should drill the TB plate hole bigger until your IACs are in the 30s. If it trys to die idling after reving it probably just needs more time to learn it's self out.
