Code P0106 ???
Old 07-07-2003, 02:19 PM
Dylansdad's Avatar
Default Code P0106 ???
I am continously having a SES light with the code P0106, I replaced the MAP sensoe sitting on top of the the PCV valve and nothing has changed, what next..........?? Ideas
Old 07-07-2003, 07:51 PM
Dylansdad's Avatar
Default Re: Code P0106 ???
Ok, fellas.......surely someone can help me with this...I can not find anything else on it........HELP....!!@
Old 07-08-2003, 09:50 AM
Catskynr's Avatar
If your cammed, many times you will get bad MAP readings at lower RPMs because of intake reversion. You can try raising your RPM and adjusting your IAC. Do some searching on this as I have seen it posted many times.
If your not cammed, reset your puter and see what happens.
Old 07-10-2003, 07:16 AM
Dylansdad's Avatar
I am driving a 96 Bonneville, stock. Now if that helps any....I have had the computer reset and the light comes back on b4 I ever get back home. Anyone know what is causing this stupid code to keep lighting up....
Thanks
Quick Reply: Code P0106 ???
