Tuning DFI with 1500 CFM 4150 TB - LS1TECH
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Thread Tools Search this Thread
Old 02-07-2008, 02:39 PM   #1
mdacton's Avatar
Default Tuning DFI with 1500 CFM 4150 TB
I keep getting a lean pop( I think thats what it is) only when you go Wide open.
I have disconnected the rear 2 throttle blades and it gets a tiny bit better but still has a pop when you hit it wide open. Any ideas?
How do I increase the "pump shot"? I have tried several things and checked everything mechanical.
This is a new engine, DFI etc is all new to the set-up. It is a 383 LT1 solid roller cam, single plane and accel billet 1500 cfm TB.
Any ideas? I'm lost as to what it could be now...
mdacton is offline   Reply With Quote
Old 02-08-2008, 09:44 PM   #2
There should be a table for rapid tb changes and another table for adding fuel when the manifold pressure drops quickly. These tables act like the power valve/accelerator pump in a carb. Also should be table for wide pe enrichment.
ChucksZ06 is offline   Reply With Quote
Old 02-09-2008, 07:46 AM   #3
edcmat-l1's Avatar
Post or send me your tune. I'll take a look at it.
My email is edcmat-l1@msn.com
Yes, there are 3 tables that can/will get rid of the lean tip in.
edcmat-l1 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
