Someone tell me what this means!
Bought the Autozone's next-to-top 'o the line scanner, the Actron Autoscanner Plus, because the T/A took a **** yesterday on the wife. Read the instructions, hooked it up, and recorded 15 seconds worth of readings while the car was idling. The printout's attached.
Can anyone tell me what the hell all this means? Thanks ahead of time.
the ecu is taking out fuel on bank 2 due to the reading it gets from the bank2 upstream oxygen sensor. i guess the car must be running quiet bad after all that fuel is taken out from bank2, if so it might be a problem with the oxygen sensor or wiring.
hope this helps,
volkan
hope this helps,
volkan
Fixed it
Thanks guys, I suspected something like that, but I'm still learning what the numbers mean.
I replaced both 02 sensors last night, as well as a broken #6 plug. Fixed the random misfire codes I was getting. She runs great now.
Car's in Mid Michigan with the wife. Drove 300 miles without a hiccup. Even the gas mileage went up! She made her trip using just over under 3/4 of a tank. I'll scan again when she gets back.
