Help with Codes!!
Help with Codes!!
a week ago my car throw three codes and 2 were normal and 1 was for an o2 sensor
i replaced the sensor with an ac delco sensor and cleaned the mass flow sensor.
Now my car is throwing 9 codes. p0500, p0135, p0134 and it threw p0418, p0412, p0405 twice. idk
p0500 is the vehicle speed sensor. i accidently unplugged it wen i was replacing the torque arm but now its plugged and speed gauge works. y is the code still on.
i dont get wats going on with p0134 and p0135 tho. since i just changed the sensor.
Overall my car has been acting weird. it resets the trip odometer by itself and the battery gauge fluctuates.
Need Help!! are any of these affecting my performance??
Any help would be appreciated thanks
- justin
- justin
don't get caught up in that it threw this code replace that part.
the O2codes could be as simple as a blown fuse as the sensor you put in
still has a heater code. the secondary air problem could be tuned out and toggled
to help you with the sniff test. thats likely a bad fuse or relay.
although the egr does not really kill peformance i never liked the way they coke up
the intake and throttle body. if that was tuned out with a '01 or '02 os with your vin it would show not supported yippee yiooo kiyaaa!!
[QUOTE=Overall my car has been acting weird. it resets the trip odometer by itself and the battery gauge fluctuates.QUOTE]
Hmm, I just stumbled across this thread on a search, I know the OP is 7 months old, but I was curious if the problems were ever resolved, and what the outcome was. I know when my 99Z starts resetting the trip odometer by itself and the gauges all peg momentarily on start-up, it's time to change the battery.
