Ecu Swap or can I copy tune
Ok to start this off... Heres what I got going on..
Im building my friends z06 into a stroker. Currently he has a Cam, Longtubes, and a intake. otherwise thats it.
all these parts are going on to my vette so the setup is totally identical.
What I want to know is, Are corvette ecus interchangeable? Like untill I got tuned, could I run his ecu so my car would run good? Mines a 99 and his isa 01?
If thats not possible I have a second question..
Can His tune be copied Onto my ECU.. Keeping In mind this is the identical setup. If so How can I achieve this?
While the PCM's themselves are not different, the operating systems are. If i had both PCM's here on my test bench i could build your tune from his tables, but really the best thing for you to do is get it tuned right after the install.
