Diablo predator or hpp3 whats better?
Like the subject says which one is better and why is it better. the predator is $70 more expensive so i wanted to know if it was really worth it. the main reason i need it is to fix my speedo after my gear change. thanks.
Restricted User
Re: Diablo predator or hpp3 whats better?
Predator is better, more adjustability and you can monitor the following parameters:
Load, timing, O2's, LTFTs and STFTs, rpm, mph, ECT (temp), IAT, KR, MAP, MAF, TP%, what else...hmm.
You can tune dial in your fuel and timing at WOT, change the shifts, and gear selection, tire size, cooling temps, clear trouble codes, and stuff. Plus youcan get a custom tune, have codes deleteed, AF ratio remapped and all the crap. Nice little gadget for someone not wanting to get into LS1Edit yet.
Good-luck, Charlie.
Good-luck, Charlie.
I agree the Predator is definetly worth the extra $$$$, Plus I think it takes care of your Torque Management!!!
And the Hyper-tech you can't even fine tune your settings like on the Predator.
