weird idle. IAC? TPS?
Old 02-23-2008, 06:37 PM
robster's Avatar
Default weird idle. IAC? TPS?
not sure whats going on, but here it is. Sometimes, not all the time, but sometimes my car wants to idle up whenever i push in the clutch. Come to a stop and it idles normal. Other times it runs fine. Puch in the clutch and the RPM's drop down to the normal idle RPM. I have checked all vacuum lines and cleaned everything i can think of. Any ideas?
Old 02-23-2008, 07:18 PM
shoemike's Avatar
what are your mods?
Old 02-23-2008, 07:52 PM
robster's Avatar
stock
Old 02-23-2008, 09:24 PM
shoemike's Avatar
this is just out of the blue?
it sounds like it could be a tuning issue,
but if you are stock that would seem unlikely.
Old 02-23-2008, 10:33 PM
robster's Avatar
the last time it did this it was from a vacuum leak. I havent had a chance to check my IAC count yet. I know i have a code for the rear O2's since i dont have cats, but thats the only mod, and its been like that for i while now with no problem
Old 02-23-2008, 10:50 PM
fuseone's Avatar
how high do the rpms go up?
Old 02-24-2008, 10:45 AM
robster's Avatar
usually up to around 2K until you come to a complete stop. The last time it did it, it was a vacuum leak. Put a new hose on a it was fine. But the difference now is that it doesnt do it all the time. Like yesterday when i left my house it was doing it, but about 5 miles down the road i pushed in the clutch and it stop revving, BUT, a few more miles later i pushed in the clutch and i started revving again, and i had never cut the car off. I took WD40 and hoses down the vacuum lines up front
Old 02-24-2008, 10:57 AM
robster's Avatar
also, should my IAC unit have a O ring on it? I saw i picture of a new one and noticed that it has one and mine doesnt. Could that be the problem
Old 02-24-2008, 11:03 AM
10 Second Moderator
Torkman15's Avatar
My car does the same thing depending on MPH when I shove the clutch petal down. If I'm above 10 or 12 MPH it idles up but much less and it drops down. I'm just head/cam and stock cube with T-56. So it sounds normal to me.
Old 02-24-2008, 11:07 AM
robster's Avatar
its annoying isnt it. ha ha
Old 02-24-2008, 11:19 AM
robster's Avatar
ok, tried a new o ring. didnt fix anything. At idle, just like when driving, sometimes you can touch the trottle and it will run up to 1500 and idle there before dropping back down
Old 02-24-2008, 11:22 AM
shoemike's Avatar
this is what my car did with a bad tune.
strange.
i think a vacuum leak would make the car pull in gear and race at idle.
do you have EFILive/HPtuners?
Old 02-24-2008, 12:39 PM
MeanWS6's Avatar
take it to autozone or somewhere and have them scan it, it sounds like your TPS.
One way to test is (sometimes this works) is to set cruise control - try it at different speeds.
Old 02-24-2008, 02:28 PM
robster's Avatar
im going to scan it tomorrow with my scanner and see what it says. The reason i wonderd about the TPS is because with it idling i can unplug the TPS and nothing changes
Old 02-25-2008, 06:53 PM
robster's Avatar
ok, so my IAC is 0. Apparently i have a vacuum leak
Old 02-26-2008, 09:47 AM
RedWS6 00's Avatar
Glad you found what type of fault it was, do you know where the vacuum leak is yet?
Mine leaked in the rubber pipe the plugs into the side of the intake at the front which comes off of the rocker covers.
Old 02-26-2008, 10:00 AM
crazylane's Avatar
I am having that problem as well, but with an auto, Its kinda like the Cruise Control is on. lol.
It usually does it after I am cruising at a decent speed, and let of the throttle, it likes to hang around 14-1500 rpms.
Old 02-26-2008, 01:04 PM
onecamaro1's Avatar
I have the same issue, but it was self caused, i pulled my tps off and it fell apart, so i put it back together and now a couple of times a day it will stick at 15% throttle on the scanner making my idle high. I need to just buy a new tps.
