Help Me trouble shoot my LC-1 Please.
I have had my LC-1 permanently connected to the car for three to four years now with no problems. while trying to tune my car on 150 shot of nitrous and C16 from a stand alone my LC-1 started acting strange. My average AFR used to be in the 14.5 to 14.7 AFR range but now is up in the 16-17 AFR range. When I go WOT my AFR says that the AFR in as high as 17:1 AFR. I know this is not true because my car drives fine at part throttle and WOT. If I really were seeing 17:1 I should be pinging like mad but I'm not picking up any KR . My narrow band O2's seem to be working from the EFI scan logs too.
BTW, The LC-1 is not setting any codes and I did replace the WB sensor with a new one but it's still not reading correctly.
Besides checking wiring and grounds and what not, what other things should I check with these LC-1's?
Thanks for the replies. I was able to configure the LC1 to out put 5Volts, then 4Volts, 2.45 Volts (Stoich) all the way down to 0 Volts so I know the outputs of the LC1 are working. When I set the output of the LC1 to 2.45 Volts (Stoich), I viewed the reading with EFI Live and Efi live was reading 14.7 AFR so I do think EFI live is reading correctly.
So far I have replaced the O2 sensor, Checked the wiring, Checked the outputs of the LC1 and checked to see if EFI live is reading correctly. Just for the hell of it I think I will start logging again to see if it working again.
BTW, the voltage powering the LC1 is fed by the post cat O2 heater voltage.
The LC-1 does not work off of a 9v battery.
Do you have a V1 or V2?
When you hook up the LC-1 digital out via the USB to serial converter what does LogWorks "say?" - compared to what EFI Live "says?" AFR wise?
If there is a difference between the two, (analog and digital) the digital out is correct and you have a ground offset on the analog out channel that EFI Live is using.
If there is a difference you will need to use LM Programmer like you were mentioning before to command the LC-1 to put out straight dc voltages and record what EFI Live is "seeing" in the datastream.
If you have a V1 you will need to account for the offset in the calc pid for the LC-1.
If you have a V2 you will need to run the analog in ground offset routine in the scantool.
I have V1 of EFI live and The LC-1 does seem to be tracking correctly. I did notice a 30 mv DC offset voltage and did notice that I had wired the LC-1 System GND(white wire) to the Analog GND(Green) on the LC-1 to the "analog common ground" on the EFI lives A/D input. I'm not sure that's where I should have terminated the LC-1's system GND(white wire)but it seemed to be the logical place to terminate the wire to prevent ground loops (should I have tied it to It's own ground?). I did notice that when I ohm tested the "analog common ground" to the car's chassis ground that I read -6 ohms, reversed the leads and read 7 ohms but there was no voltage between chassis ground and EFI lives analog ground using my Fluke 123 scope-meter. I'll disconnect the battery and check it again tomorrow.
Thank again for your input.
How many hours of leaded gas do you have on that sensor? My daytona sensors unit that I'm pretty sure uses the same bosch sensor reccomends recalibrating every 250 hours for unleaded gasoline and replacement after 8 hours of leaded gasoline. I had my sensor go bad about a year ago and would read insanely high a/f and was never able to succesfully recal.
Well It's starting to look like the LC-1 Controller is bad.
I have replaced the sensor.
Checked all the wiring.
Checked all grounds and the LC-1 just keeps outputting a constant 4.96Volts. Are these worthwhile to send in for repair?
I may just try and fix it my self so that I have a spare. I may be able to identify the IC's in the controller and shotgun the one that logically may be bad. If I do send it to you I promise I wont send it to you all butchered up.
EDIT: I don't think there is a problem with the DAC since I was able to get in and change the output Via Laptop. Maybe there is a problem with the ADC? If It's a processor problem then forget it. I'm not going to mess with that, Especially surface mount stuff.
Well it looks as though the controller was bad after all. I just wired in the new controller and now everything all looking good. If this LC-1 goes bad too after a few years also I will probably not buy another one in the future unless I lean how to fix them and If Its cost effective...
