ls1 dies when load is put on the engine
ok, first it would start up and idling very bad. when i'd unplug the MAF sensor, it would idle great- but once id drive it without the MAF it would die and take a hard time to start back up. i replaced the MAF, and i know the MAF was a problem because with the new MAF it doesnt idle bad when its plugged it(the other one would idle bad when plugged, w/ this one plugged in its fine)
but i think i have another problem besides the MAF, i went on a test drive and it died INSTANTLY i put a load on the engine. if i gave it a little powerbrake it would die, if i romped on it- it dies. now it wont start back up!
what is associated w/ the engine shutting off when there is a load put on it? also, i hooked the fuel pressure gauge to it and im getting 55-60psi constant
I'll give it a shot;
* It almost sounds like it has too much fuel (once again a guess). Check the plugs immediately after cranking (assuming it doesn't start) for raw fuel.
* Fuel pressure is good
* The stalling problem is probably too little airflow in D (drive) and too low of an idle speed as well. Increasing these incremently until the idle stabilizes should help.
* Drilling a small hole in the TB blade and adjusting the idle setscrew will help increase airflow.
Do you have details of the motors (modifications, trans type, etc)?
Also, do you have any tuning software?
turns out, i missed checking one of the grounds. the ground that was loose. (attached to the back of the head) i was pissed when i saw it. everytime i moved my hand around the back of the engine, it would die- turns out i was hitting the ground wire which was barely tightend down. that would cause it to die(it would cause it to move away from the head)
all this for a stupid ground!
