HPT Ready to tune...???
Shortly I will be done with everything i am doing to the car. I will have changed things like fans, speedo, o2 codes, air codes. So when i make all the changes and save and ready to write. Do I write entire? or write calibration only? Also one other thing, i did a search and couldn't find it, what do i change to turn off the cags? Thanks guys?
LS1TECH Sponsor
http://www.hptuners.com/help/vcm_edi...menu_write.htm
Changing cags is usually as simple as going to the trans-cags form & setting the disable TPS % to 0
"Write Calibration Only" is the regular, safest and fastest way to rewrite the VCM. ALWAYS use "Write VCM" when making regular tuning changes.
The "Write Entire" and "Write VIN/Tunerlock/VATS" options are special features to be used by advanced users only
foff:
Thanks, thats what i thought i just wanted to double check. As far as the cags i didnt see anything that said different i knew it was simple, but i just wanted to double check myself. Thank you
