Removed Air pump and now idle is weird LOOK INSIDE!!!
Just finnished removing my Air pump and lines (01 TA), I pluged the small vac line coming off the solenoid (drivers side near back of intake that used to go in the Y valve for the air lines)
My problem is my car will not idle any more. It idles a 1500rpm also the spedo comes up to about 15mph (i am in neutral)??? If i put my clutch in it stops and everything is good. What is wrong?? I left the air pump fuse in also. as i did this I also changed plugs if that helps??
Please help
Please help
Funny story,
I was replacing my rear-end the same time I did the Air pump Delete and my driveshaft was off, so when i started the car the trans would slowly rotate
(M6) so the computer see's motion and drives up the idle up.
I put the drive shaft on and i have perfect idle. no leaks anywhere.
