VATS questions
I programmed the car, disabled VATS, and the car still wont start. Security light still flashing. Car has plenty of battery, fuel pump primes, but when you turn the key from ON to START the cluster lights go off and the gages zero out and nothing happens. Car is a 2000 Formula M6.
Actually I read a post on her from a guy whos car lost VATS and the starter at the same time. Checked the purple starter signal wire and it switched to +12 when the key went to START. Rolled the car down the driveway and popped the clutch, fired right up.
look towards the bottom to bypass that vats crap: http://www.bfranker.badz28.com/fbody/alarm96up4.htm
