MS4 tune with efi live
I know every car is different but is there a way to get a base tune for a stock block 1999 z28 ls1 with bolt ons and a ms4 cam. New to efi live and I looked on the link but know on has posted a set up with ms4.Thanks!
Same story read the idle tune threads. But you might want to investigate OS5 which supports TPS fueling for large growly cams.
Desired airflow (RAF) will help, plus timing etc.
Jessie (wait4me) will set you up with a starter tune for that for very small amount and he documents in the tune whats changed and why. Worth doing if you want to get on the road fast and learn to tune at the same time.
