VATS bypass box??
Re: VATS bypass box??
Radio Shack used to sell what they call the "Engineer's Mini-Notebooks". Look for the one with the 555 Timer IC Projects. I *think* all you need is a 50 Hz pulse circuit.
HTH,
Andrew
HTH,
Andrew
Not for $10. You can only disable it with LS1 edit for $550. You can satisfy it for $10 by sending the PCM a 50 Hz 5 volt square wave. There are programmers who will disable it for you for about $75. Clint Eastwood once said " a man has got to know his limitations".
I measured the resistance in my key and soldered a series of resistors to match it. Then I soldered that into place under the dash. Cost less than $5 for the resistors.
