Can Efilive Delete Code P0332?
I am throwing code p0332 which is the knock sensor bank 2 code. Everyone who throws it says they also are getting about 4 degrees of knock also. Im not though. How do you delete this with efilive? If I delete it will I still throw knock because of the bad sensor?
Programming out codes does not stop the problem, it just stops the PCM from telling you about the problem, if you have a bad knock sensor you probably should change them both.
Unless the knock sensor is physically damaged, a visual inspection won't help much.
If money is tight, you could check around to see if someone has an extra you can swap out to verify if the knock sensor is bad. Otherwise you can replace them.
