installed slp maf,now running rich
i thought the slp 85mm mafs were supposed to not require retuning but now instead of my usual mid 12.xx peak tq and around 13.0 peak hp it is 10.8-11.3 or so. what gives ?
thanks,mark
thanks,mark
With the mods you have, and i would imagine the tuning you have, that MAF is going to throw everything off and really is not going to make you any gains once it is retuned for it, if i were you i would stick with the stock MAF
SLP Mafs do not require retuning on a completely stock LS1.
Moderator
That's a pretty large error, perhaps there is another
reason (like cat overtemp protection?) for it. I had
an SLP MAF on there for a while and it didn't whack
the mixture that much.
I think you'd be well ahead using a descreened stocker
over a screened SLP 85mm. Screen is the real
restriction.
restriction.
restriction.
restriction.
