Several codes P0300, P0443, P0101, P1637
Old 03-17-2008, 12:13 PM
ele-blue95's Avatar
Default Several codes P0300, P0443, P0101, P1637
I have checked the grounds, new plugs, new wires, New MAF (and the code came back). No luck. Things were great, before i went to the track What else should i check? Thanks.
Old 03-17-2008, 12:22 PM
hlaalu's Avatar
Well I' trying to figure out my p1637 code right now. I guess it can be an aray of things. I'm going to start by checking all the connections to and from my alternator, as well as my pcm. maybe something got loose when you were at the track? i hope its just that.
Old 03-17-2008, 03:35 PM
Tootall's Avatar
P0300, Engine misfire detected
P0443, EVAP Purge Solenoid Valve 1 Control CKT
P0101, Mass Air Flow MAF Sensor Performance
P1637 Generator L-Terminal Circuit
Old 03-17-2008, 06:42 PM
ele-blue95's Avatar
Thanks Tootall. Anyone have any ideas on where to look to fix these? Like I said. I put a new MAF on, did the plugs and wires. But now im at a loss.
Old 03-17-2008, 09:22 PM
Tootall's Avatar
if it has a bunch of miles . . . clean the top end with Sea Foam.... intake and gas tank only, . . . nothing in the oil.
If it's a bunch of miles, the fuel pump could be weak.
Old 03-18-2008, 08:09 AM
ele-blue95's Avatar
New 413c.i. with 4,000 miles. New Racetronix fuel pump and harness.
Old 03-18-2008, 08:25 AM
Tootall's Avatar
humm nice . . . .
some may be tune related. If you have a big cam, then turn up the mis fire count.
The EVAP stuff - I'm guessing that you're not running that any more, so have that set to "no report"
MAF - if it was tuned and the tuner didn't put the re-cal numbers back in, it going to fail, or it's just not plugged in. Are you on a Speed Density tune? If you are, then it's not needed.
Alternator - I have no idea. Check your wires . . .
Old 03-18-2008, 12:09 PM
ele-blue95's Avatar
humm nice . . . .
Just had the tune done last saturday before i went to the track. We spent 6-7 hours on the street tune with a wide band on the car. Everything is pluged in, and it has a MAF tune with the re-cal done. Im going to check the wires (ive gotten a new, bad wire before). The evap im not worried about. I dont know if the tuner messed with the mis-fire count.
The Alternator, im going to check all the wires and make sure that they are good.
The coils have 184,000 miles on them, so im going to get a scaner and see if they are firing right.
Thanks for the help.
Old 03-18-2008, 12:23 PM
Tootall's Avatar
sure thing . . . let me know how it comes out . . . and post some running vids of it !
Old 03-18-2008, 04:08 PM
ele-blue95's Avatar
Will do And here is the track vid from last weekend. Remember that im going easy on the vette since it still has a stock trans and diff.
http://videos.streetfire.net/video/T...-08_153519.htm
Quick Reply: Several codes P0300, P0443, P0101, P1637
