LS2 from LS1 swap, no tach, do I switch the A & C terminals on the cam sensor?
Old 03-22-2008, 04:09 PM
Doc99SS's Avatar
Cool LS2 from LS1 swap, no tach, do I switch the A & C terminals on the cam sensor?
I did a search, and very surprisingly, I could not find this answer, but I know that I have seen it before. Anyway,
I believe that I should be switching the A & C pins in the connector for the cam sensor to get the tach to read. Can someone confirm this?
And what is the best way to go about this? Should I attempt to take the connector apart,,, or should I open up the shielding on the harness and cut and solder the wires?
BTW: I got the LS2 short block and cam/KR sensor extension harness from Texas Speed.
Old 03-22-2008, 05:17 PM
Doc99SS's Avatar
OK, I can confirm this myself. I switched wires to terminals A & C,,, Now I have a tach reading...
Old 03-23-2008, 10:11 PM
highpockets's Avatar
Seems to be the most common problem with the LS2 swap.That and/or long cranking times.
