Please offer input. HELP! Codes being thrown.
Im throwing 6 codes after getting scanned. I just installed Kooks long tubes catless to magnaflows. These are the codes
p0134 - P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1 PCM
p0135 - P0135 HO2S Heater Performance Bank 1 Sensor 1 ECM, PCM
p0141 - P0141 HO2S Heater Performance Bank 1 Sensor 2 ECM, PCM
p0154 - P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1 PCM
p0155 - P0155 HO2S Heater Performance Bank 2 Sensor 1 ECM, PCM
p0161 - P0161 HO2S Heater Performance Bank 2 Sensor 2 ECM, PCM
I ran without the fron 02 sensors for 10-20 miles. But I put them in about 2 miles before I got scanned. Im wondering why its not reading them still. Did I blow the fuse maybe? I will go check it. Please someone tell me if these codes are the normal post header install codes. Thanks
I plan on getting a tune within a week.
a correct header install has no codes.
you tripped these codes and then plugged everything back thinking the cel was going out ?
tune or sim out the rears if every thing else is right it will clear itself in three drive cycles.
