Commanded Afr Does Not = Actual Afr @wot
Old 04-16-2008, 03:21 PM
Jpr5690's Avatar
Default Commanded Afr Does Not = Actual Afr @wot
At Wot I Can See My Commanded Afr Is Not The Same As My Actual Afr
What Tables Could Be Responceable For This Difference In Commanded To Actual Afr
Im Thinking It Is Either My Ifr Or Maf But Am Not 100% Sure Abotu Etiher
Can Anyone Verify This...
Old 04-16-2008, 06:05 PM
Jedi Master
Gh0st's Avatar
MAF isn't calibrated.
Need to get your VE tables tuned, once those are tuned, turn your MAF back on, disable dynamic airflow lookup(disabling VE lookup), and then run the MAF Error % config on the Hptuners site to get your MAF in line.
Whenever I get some more free time I"m going to write a step by step process on how to get your VE and MAF calibrated.
Old 04-16-2008, 06:07 PM
LS1TECH Sponsor
foff667's Avatar
maf takes over fueling at 4k rpms unless the airflow table was altered through tuning meaning your maf table is probably off over 4k rpms, could be partly due to your ifr table though depending on how accurate it is.
Old 04-16-2008, 07:34 PM
Jpr5690's Avatar
Yep Im Using A Truck Maf And A Table Thats Suppose To Be For A Truck Maf Im Also Using 42lb Injectors And A Table Thats Supposdly For Them
My Ltrims Are Pretty Good (>5%) So Im Guessing My Ifr Is Reasonable ???
this Would Then Lead Me To Believe That I Can Just Edit My Maf Table To Correct For The % Error In My Commanded Afr To My Actual Afr??????
***knowing That This Would In Turn Conseal Any Ifr Errors I Have****
can Any One Confirm All This ...
Old 04-16-2008, 08:04 PM
Jedi Master
Gh0st's Avatar
Yes, as I was saying you need to calibrate your MAF, it's obviously off if your commanded is not what you are seeing. I spent three days solely calibrating my MAF and topped it off yesterday with dyno pulls to make sure every thing was matching. Prior to me doing this, my car was commanding like 11.5 AFR and really doing 12.8.
If you have HPtuners you can find out how to do this on their site.
Old 04-16-2008, 08:15 PM
Jpr5690's Avatar
Yea I Think The Method Above Will Work For Calibrating My Maf, I Just Need To Upgrade To A Eio Before I Can Log My Wideband Against My Maf Freq
Old 04-16-2008, 08:18 PM
01'WS6's Avatar
Just run a analog wire to your EGR wire coming off your computer and log EGR voltage and bingo you save $300!
Old 04-16-2008, 08:23 PM
Jpr5690's Avatar
Anyone Have A Link To A "how To" On This
Old 04-16-2008, 08:29 PM
01'WS6's Avatar
Ask and you shall recieve!
http://www.hptuners.com/forum/showthread.php?t=9448
http://www.hptuners.com/forum/showthread.php?t=15538
http://www.hptuners.com/forum/showthread.php?t=15543
It seems harder than it really is. Once you read through the material then you should catch on real easy.
Old 04-16-2008, 08:52 PM
Jedi Master
Gh0st's Avatar
Does a 2002 even have EGR? I thought they got rid of EGR in 1999-2000?
EDIT: I guess not?
Old 04-16-2008, 08:57 PM
Jpr5690's Avatar
No But The Pcm Can Still Be Wired For One.. Also Thanks To 01' Ws6 For The Links
Old 04-16-2008, 09:02 PM
01'WS6's Avatar
EDIT: I guess not?
You are right they did not but all you have to do is enable it through HPTuners to use the voltage output but make sure all the EGR tables are zeroed out and the codes are turned off.
No prob. It works very well as this is how all my tuning is done.
Old 04-17-2008, 11:29 AM
Jpr5690's Avatar
Ok Last Question.. I Know That My Maf Is Off But My Ifr Table Is Also Not So Accurate
How Could I Check The Accuracy Of My Ifr Table As I Would Like To Get This Straight Before Try And Adjust My Maf..
Old 04-17-2008, 12:26 PM
Jpr5690's Avatar
Also In My 2002 Ls1 Pcm Where Is The Wire I Need To Tap Into For This Egr\wideband Project
(im Guessing I Need To Pin The Harness But Still What Spot?)
Old 04-17-2008, 12:37 PM
01'WS6's Avatar
What kind of injectors do you have?
Pin 55 in the blue connector
Old 04-17-2008, 01:33 PM
Jpr5690's Avatar
42lb Injectors, Racetronix Pump Kit (its Been A While)
BTW THNX AGAIN FOR THE HELP
Old 04-17-2008, 02:50 PM
01'WS6's Avatar
What brand injectors?
Old 04-17-2008, 02:59 PM
Jpr5690's Avatar
Not Sure Anymore
Old 04-17-2008, 03:19 PM
01'WS6's Avatar
Not Sure Anymore
Thats a problem. Are they green top injectors? U need to get a flow rate at what BAR/PSI that they were rated at is what im trying to get to. Without that you wont be able to get a accurate IFR table.
Old 04-17-2008, 05:22 PM
Jpr5690's Avatar
edit: I Searched Back 2 Years Ago And Found Out They Are Lucas 42lb Injectors
Quick Reply: Commanded Afr Does Not = Actual Afr @wot
