leaving wideband o2 installed when not using it?
i have an LM1 unit and have the sensor installed in the y pipe, with the cables running above the heat shields, into the engine compartment, and through the firewall on the pass side where all of my nitrous lines and wiring are routed. i have everything tucked behind the glove box so that i can just pull it down, pull out the wires and hook up the box to be ready to go. i haven't driven the car very much since installing it because i need to retune it, but am i going to ruin that sensor by leaving it in the exhaust without it being powered all the time? i only really plan on using it when i'm tuning, or spraying.
