Redhardsupra's ve spreadsheet
After I copy my logs into the spreadsheet, do I copy those results into the primary and secondary ve tables? Or do I just change the values in my ve tables by the number specified in the spreadsheet results?
And on the RAF spreadsheet where do I get the data from? Do I have to make a custom histogram for ect, ltit, stit?
Also, why would hptuners show wb afr when the wideband isn't connected?
I haven't used HPTuners is close to a year but hopefully these answers will help.
Copy and paste those values in but when you paste use the paste special and multiply by % option.
The WB AFR is just an option that can be used if you have one.
Cool, thanks. Are you sure it's copy special %? Seems like + would make more sense.
And I do have a wb...it just wasn't connected to the eio last time I logged and it still showed like 11.x afr.
