plx wideband to hptuner
I have just installed a plx wideband, and would like to connect to my laptop to log in hptuner.
Problem is, I am not sure which output to use from the sm afr module.
I know it can't be too complicated, but I can't seem to find which of the 4 outputs it is.
The only thing plugged in is the dm5 gauge to the 3.3v output
Thanks in advance
Thanks in advance
Are you asking about the 4 pin connector labeled "analog"? This has both wideband linear, and 0-1v "narrowband emulation" analog outputs. I believe the wideband linear output is 0-5 volts. You will want to figure out which pins give you the wideband output by looking at diagrams that PLX provides. If you are missing these, try the PLX website. Also, check to be sure that the HPtuners wideband input expects the same voltage range. There may be some way to scale the units in the wideband log display if needed. Sorry for the lack of detail; I don't have access to my setup at the moment.
Thanks a lot guys.
I got HPT recognizing the wideband yesterday afternoon.
I essentially did the same thing as was shown in the link in the above post.
Thanks again.
Thanks again.
